Camera via telephone line
PLC Primer
Guest
P
Hi All,
Could you please suggest me a available solution for this application?
I have to monitor a warehouse via a camera from very far control room. That warehouse only have telephone line, i don't want to use a computer at warehouse.what is kind of camera i should use so that i can monitor the warehouse at control room ?
Please help me !
You could try diginet security cameras as one option. When you start installing cameras that could be potentially used for security reasons. You run into a new set of requirements by law. One of those requirements is that the interfacing image cannot readily modifiable.
Can you get DSL on the phone line?? 1) It'll be much less expensive to install a Small PLC with a secure seb cam and monator it Over a DSL connection, rather thne using an always connected phone line.
Something like PCanywhere, VPN, or I think WinXP has a feature for taking over a remote computer also..
Best of luck with it, Mike.
DSL would be the simplest (and maybe only?) solution. Plug a network camera into the DSL modem and you're done. The network cameras have a webserver built-in, so you don't need a PC... (y)
beerchug
-Eric
Are the phone lines running from the warehouse to the control room? If you could get a dry pair in there phone cables you could ust a device fromNVT to send the video over the phone pairs. Ive used hundreds of them and have gone as far as 2 miles without a bit of losshttp://www.nvt.com/
Hello, I am currently working on project to pull barcode data from IFM camera to Siemens 315 2 PN DP using Portal Software via. Ethernet. We have...
1,716
Hello all I've got a cell with four Keyence IV3 cameras that are saving images to a FTP server, we are also labeling the parts with a time date...
262
The data structure I'm looking for for the inputs and outputs from the camera is Dint[125]. When I installed the CV-x300 Keyence module it is...
336
I have a Cognex Insight 2000-130 camera that I'm trying to get talking to my PLC. Both are connected to the same router via Ethernet. Thus far...
1,232
Hello, i am a uni student and i am trying to specialize in automation, i always had this project in mind that i can sort different items, for...
917
