Siemens Portal to IMF camera via Ethernet
PSU
Jul 2009
South Carolina
26
Hello,
I am currently working on project to pull barcode data from IFM camera to Siemens 315 2 PN DP using Portal Software via. Ethernet.
We have been able to ping the software through dos but can not communicate through portal hardware configuration.
Thanks for responding JRW,
The connection is TCP/IP
W
We can see the PLC online (Ethernet)
The camera is not an accessible node on the software (siemens portal)
Profibus is not an option in this application
Thanks again for the help
Using the O2M110 ?
From fast glancing at the manual, (if this is even the camera your using) it shows a codesys block which is interesting.
I wonder if PROFINET is supported
You will probably need T Send and T Receive Blocks (Im just guessing though) But you should be able to see the mac through Portal's Online Access
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
210
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,522
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,179
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,173
