Telesis and slc505 communication
Thanks again,
If it wasn't for needing to write to two text fields I could probably have it working.
Once or If I do get this thing figured out I will make sure I post my findings.
Got it,
It seems that the Telesis is looking for ASCII code from a PLC rather than decimal or Hex, while I am controlling and talking to the Telesis via a PLC.
Here's what I did . . .
Wrote a basic rung of logic, with an AWT output and another AWT branched below that.
The string file is ST25:1 and ST25:2
The first string writes V01Hello^D to the Telesis when the rung of logic is true
The second string writes V02Hello^D when rung is true.
(V = Variable text, 01 is the text field where I want to place text, Hello is my text, and ^D = EOT or End Of Text.)
The ^D was my main issue while posting to this forum. It seems that in the Telesis under the 'Properties Section' while in 'Host' under "Prog' the Terminator was set on 13 which represents CR or 'Carriage Return' My PLC was sending a ^D or EOT but the Telesis was looking for 13 (CR) so I changed the 13 to a 4 and all works like it should.
I hope this will help another Engineer in the future communicating to a Telesis.
Thank you everyone for your help.
Hi, I'm currently working with a Telesis Scriber and I have not figured out how to have its Done output be turned off automatically after each...
761
Good morning. I have been working on integrating a Telesis TMC470 using their #77918 ethernet adapter. I can get a string to send, but it is not...
2,365
Any one have any experience getting a Micrologix 1400 to communicate with a Telesis TMC470 Printer? If so what communication protocol did you use...
20
5,855
Hello, as the title stated I'm running into a problem with socket messaging a Telesis TMC470 controller and a 1769-L18ERM-BB1B using TCP/IP over...
3,014
Hello, I am trying to figure out how to send string data to certain fields of my Telesis laser marker from Rslogix 5000 through a Telesis EIP to...
2,223
