Dave Soper
I have a Temperature transmitter connected to a type "J" thermocouple. The output is scaled 0 to 400 deg. F at 4 - 20ma.
This output is going to an A-B NI16NI analog input module. In the program I am using an SCP for this input. The raw data is set for 3277 for the 4ma input and the max raw data is set for 16383 for the max raw data. the output from this is 0 to 400 deg F. I began troubleshooting this yesterday. I have been told that it has been working ok during the past few years, until a few months ago when it started indicating the wrong temperature. The transmitter is a Rosemount Hart compatible, I think it is a 3144, No name plate left. Using the Hart communicator, it shows the correct temperature and the correct output. at 204 deg. F it showed 12.12 ma. The plc program online indicated 11392 for the raw data. It should be about 9830 or so. Connecting a ma meter in series indicates the 12.06ma.
Any ideas what would cause the raw data to be so far off. I even tried it on 3 or 4 different inputs, with the identical results. so I think that eliminates the plc as being the problem, but right now I am lost! HELP!
