tension controller problem
akhunzada136
Feb 2014
karachi
hi dear all . i am installing tension controller zxt-b600 for winding roller.it is working manually but in auto mode it is not variating its speed to adjust tension . my load cell are new one and wire upas per instructed in manual but one of load cell have value above 20000 ....inspite of all attempts i am finding its solution please help me out
Are these roller mounted load cells?
Make sure the physical setting follows the directional arrow on the load cell if it has one. Otherwise I would check the load cell mechanical installation.
thanks dear for suggestion it is wired up as per manual instruction.with red-5v,green in+,white in- ,and black 0v ....
By the sounds of it the load cell should be providing a mV output. I would take a multimeter and measure across the green in + and white in - wires and check your reading. With zero tension I would assume this should be as close to 0V as possible. If you have a high reading (20mV+) then this would be your problem.
Also, disconnect all power from the load cell and measure the resistance between the red and black, and the green and white. The readings across both pairs should be the same. Depending on how the load cell is constructed would be something like 350ohm, 700ohm, 1000ohm, 2000ohm.
If you do both of these tests and get 0mV and good resistance readings you should be able to rule out a faulty load cell.
do you know dfe steady web tesion controller?and have steady web version 16d manual?now i need it.one tension controller now is not displaying the...
4,558
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
245
I am currently working on a site with a faulty Powerflex 755, we have a replacement but have no access to the parameters with no license for...
157
Hi everyone, got a Siemens S7-1200 collecting data off one our furnace lines. I'm getting some interesting activity I'm working on cleaning up in...
710
Hey all, One more Newbie Question I just posted up about the same exact line on a separate problem but I have a challenge that several of us at...
704
