Terminator I/O T1K-modbus Direct Automation
e_pramod
Feb 2005
29
We are using T1k - modbus terminated IO (Remote IO) with direct automation plc DL-06. We are trying to communicate between the two using the MRW & MRX instruction but it doesn't work.
We have also checked using modscan32 software with RJ12 port with serial cable but they are not talking to each other.
the dips switch setted are as follows
SW1 - ON, SW2-OFF, SW3-ON, SW4-ON, SW-5 -OFF, SW6-OFF, SW7-OFF, SW8-OFF.
Please Suggest
Pramod
The RJ12 port is only for programming of the T1K-MODBUS, the 15 pin port must be used to access the modules.
DL-06 work perfect with modbus.
1st you need to setup the 2nd port to modbus baud rate prity ect.
2nd check your cabel.
If you still have problem I would contact with Automatin Direct They will help.
Ok RJ 12 is the programming port, we have connected on 15 pin port of terminator and to dl06 onboard port2.
Now the situation is that we are able to force digital output but unable to get values from Analog modules(T1K-08AD-1) on terminator.
we have write the intruction in the pattern LD-KF202, LDK64, LDA O2000 ( location on which i want to write the values that is V2000), Rx TA0.
Please suggest.
Pramod
Hi All, I have an application where I am connecting a Terminator I/O Profibus base (T1H-PBC) to our CTI-2500 (Ti545/Siemens 505) PLC. Added the...
2,277
Hi guys, Just flew back to Dutch and got on the boat. Went over a problem they have been having with my relief before he left and have poked at it...
34
10,844
Hi All I have a controllogix controlnet network using just 1 remote io connection (1769-ACN) the cable is fairly short less then 3 M when I plug...
2,252
Hey everyone, i'm trying to use the message instruction in a ML 1400 to talk to Automation Directs terminator Remote I/O. Basically i need to know...
6,951
Hello, all. I've got an existing control cabinet that has a CompactLogix L32E with a 1769-SDN DeviceNet Scanner (which is not currently being...
1,549
