The difference between dB and dBA ?
Rob S.
Sep 2008
Maryland
739
I am getting sound samples around the plant to install a
public address system . I am curious , what is the difference
between dB and dBA ,in simple terms ? The meter I used displays it anywhere from 84 to 98 dBA around the plant.
Thanks, have a great day.
The dBA is referenced to some sound pressure level (not sure what it is thoug). When I worked alot with RF, dbm was the measurement. It's just dB refereced to one milliwatt. If you don't reference it to something a dB is just a ratio.
Way back when the phone company needed to figure out how to design speakers in phones that would be most compatible with how people hear. So they measured how people hear different frequencies. That data is the foundation today for all human speech and hearing measurements and designs and standard setting. It has been added to of course.
So as a result of all this there are three decibel scales
A B and C. The A scale is weighted to closely match human hearing. Some noise instruments have all three scales.
The A scale is the one all human noise exposure standards are set. As an industrial hygienist I never used B or C and have forgotten their purpose.
For your application I would recommend using the A scale.
Dan Bentler
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,415
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,046
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,973
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
815
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,835
