The "Imaginary Relay" Problem, Part-1 of 2
I just put random instructions together and get the FAT guy to fix it.
Yes, I do call my Factory Acceptance Tester the FAT guy.
Yes, I do call myself the FAT guy when running a Factory Acceptance Test.
Do you call the PLC the FAT Controller?
For folks that INSIST that the method that helps them understand a concept is the best way for everyone, I say take a deep breath. Different people learn and process information differently. To some people the XIC/XIO construct does a better job explaining the concept. For others the relay model is more intuitive. As far as I'm concerned the universal perfect model has yet to be invented.
Agreed.
My head works in relays. I insist on using that for myself. Everyone should use what works for them. I insist they shouldn't insist I change. 🍻
Hi, Can someone briefly explain me what exactly an "imaginary bit" is? Thanks,
2,282
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
110
Hello, I need assistance in making a Relay operation that follows the given parameters: -if S1 is switched and S2 is at off, the Lamp 1 will be...
111
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
438
