Thin client as "monitor" for HMI/SCADA ?
If you loose a connection the only way I have found to reconnect is to re-power the unit, it will reconnect fine after.
There is a really annoying task-bar that always seems to be in the wrong position on the screen so I always disable it
That is one of the functions on the task bar... it allows you to re-establish a connection if it drops out.
The issue of how the RDP or VNC displays in full-screen mode is also important to me.
It is most important to me that there is as little as possible from the RDP or VNC viewer that interferes with the operation of the remote PC.
I definitely do not want a floating taskbar that displays always (or half-hidden like VMware's taskbar).
At the most, I can accept that a menu or taskbar can be called up by means of a keyboard hotkey.
I admittedly have never set up a Rockwell Thin Client / ThinManager but I need to step in because a vendor is having trouble making the connection...
678
We got one installation that have most of the Win10 PC in a rack above the control room. In the past they always used various flavor of KVM...
2,990
I support plants with small number of HMI each, mostly 2 or less HMIs per system. they all got different HMI package, some WW, some iFix, etc...
3,262
This topic has been discussed before in this thread. http://www.plctalk.net/qanda/showthread.php?p=691496 Even though I had worked with Citrix...
1,853
I'm trying to find a cheap solution to deploy a few web browsers attached to the back of LCD monitors. For testing purposes, my Raspberry PI has...
2,265
