Thin manager vs others?
Aug 2017
Wisconsin
25
We are looking into getting Rockwell's thin manager for all of our thin clients that run FactoryTalk SE for the main functionality of designing multi monitor setups with just a TV. Do anyone have any pros or cons toward thin manger or is there a better software out there to achieve multi monitor setups with a tv screen?
Thanks,
Derek
I have Thin Manager and it's pretty good. Do make sure you're not screwed over in the licensing and guarantee that you have licenses that allow windows to run WinTMC or, if you fancy, iTMC in your iPhone or tablet.
i have thin manager and it's pretty good. Do make sure you're not screwed over in the licensing and guarantee that you have licenses that allow windows to run wintmc or, if you fancy, itmc in your iphone or tablet.
+1
We used thin manager (Wonderware) and were binning it; you need a Domain and DCHP for it to work. Just causes too many problems. Were going back to Clients that are looking at a Network Project.
Replacing Clients on thin was a doddle, Our problem was infrastructure with the issue with Domain Controller failing, left the whole system down took as the Domain controller cannot backed up with like of Acronis due to the encryption of the domain.
My tip would be if you do go to thin manager check all failure scenarios including power outages of System and Domain controller fails to restart.
I've heard this complaint before and wonder if it's not a case of more upgrades required to make it work properly? I have one redundant server in a rack with all VMs inside. My VMs are imaged every other day (all of them including 2 DC) and it works really well.
I used Thin Manager on a job in 1998 and it worked great. I would assume it's even better now, unless AB breaks it.
Not sure of any other systems out there that are competitive with it. Which might explain why its so expensive.
My tip would be if you do go to thin manager, check all failure scenarios, including power outages of System and Domain controller fails to restart.
Several Issues here.
1. You should have multiple domain controllers (at least 2)
2. Acronis is Junk / Home software. Use a real backup solution, something like Arc Server or Veeam, and DC backup and restore is zero issues. We do it all the time.
3. We have over 20 Thin Manager installs / projects, most mid to large and never a moments issue. The customers love it.
4. To each his own I guess.
Thin manager with a Dell optoplex 3000 over pxe will startup and connect then disconnect over and over again.I have 5 looking at the same...
496
Hoping for some help on this one, we are running FTVIEW SE distributed on a server. The client file runs fine on this server. We have...
3,777
Hi, I'm working on a project involving ThinManager running on windows server on a virtual machine on VSphere Esxi host for a ftServer and am...
3,212
Have several hmi screens mirrored to different Nematron Screens using Thin manager , need to have the clocks synced and 24 hour format , My screen...
2,763
FYI I went to Thindustrial 13 this week and saw in action the new Thin Manager 7.0 due out in Q2 2014. For anyone currently using it the new...
1,551
