Eric Nelson
It had better be!...Terry Woods said:The voltage across the resistor is equal to the voltage across the resistor.
-Eric
Terry Woods said:Again...
...the assumption is that the current through the Inductor, before switching, is maximum and that the current is known...
...the current is NOT known! Even if it is maximum!
as correct.I am guessing there is a 810V source connected across the inductor. Then the pos B is when the source is disconnected and the resistor connected across the coil.
Gerry said:Why should it matter? The voltage across the inductor has reached 810 V. at the point of switching from power supply to shunt resistor. From that time the voltage across the inductor and the resistor are the same and I=E/R.
I read post #1rsdoran said:How do you know the voltage across the inductor has reached 810v?
Look at the links in post #5 for some indication of the circuitry. Or, simply imagine an ideal SPDT device that can switch in zero time switching one leg of the inductor from the power supply to the resistor (other legs of L&R to P/S common).rsdoran said:Wouldnt that require it to be a parallel circuit? If that was the case then the resistor would have no bearing on the time constant.
If it is a series circuit and E=810v then your calculation may be correct, I am not positive.
Where does it say voltage across the inductor is 810v?I read post #1
I read that E=810v, and inductor fully charged, I dont see any statement that voltage across the inductor is 810v. So what is the voltage across the inductor? If the voltage across the inductor is not known how can you calculate the time till it drops to any value?R=11 Ohms, L=6200 H and E=810 V.
The switch is intially in position A and the inductor is fully charged. Calculate the time after the switch is set to position B for the inductor Voltage to drop 230 V.
And to quote myself:rsdoran said:Where does it say voltage across the inductor is 810v?
Post #1
I dont see any statement concerning parallel or series, just like DC the impedance, current, voltage etc is different between them. If parallel then 810v is across the inductor, if series...dont know because:
I saw no indication whether AC or DC which also can have a bearing on impedance and current.
Bear in mind that this is a question from a textbook, paraphrased by a high school student trying to learn some basics. There is probably a circuit diagram in the textbook. I don't think it is the author's intention that the answer to the question should be "indeterminate". Rather it is to emphasise:I suppose you could complain that the problem wasn't stated completely and clearly, but that would be rather pedantic.
RonNow it can be solved, its DC and a parallel ckt.
Please explain what you mean by this.The time constant will be different you know?
You still haven't explained what you meant by this.The time constant will be different you know?
