three persons working in one project, Step7 v5.5
May 2018
croatia
hi there,
three of us have just start working on one project, Step7 v5.5
There is few plc-s in the project and we are all writing software on all of them.
simatic manager is crashing every now and then. ...usually when two persons are working on the same symbol table.
Is there some option/setting that could make things betters for us?
Project is on file server and we are accessing it from our win7 virtual machines
tnx
You cannot.
I suggest that you split your work. If you have program description, share it and when everything has made, connect it to one.
I suggest a person per PLC... or a well thought out software development strategy, where each develops independently from each other and then copy functions into a single project.
Three people developing at the same time on live machinery is asking for trouble.
I would make one person the designated programmer - and he is the only one that writes anything in Step7.
The other 2 can look at the project, but have to have a three person meeting and propose his changes to the group. That way everyone knows what is going on and 2 people are not going to crash the machine.
If person 2 changes a subroutine and person 3 doesn't notice the change and uses it, or the result of it, not knowing the result is different - then the whole project becomes a useless waste of hard drive space, and a possible danger to anyone in the building the machine is installed in.
EDIT: ..or driving by the building or property if it involves fuel storage tanks.
It is definitely possible to have a multi-user situation in Simatic Manager, although I think it is intended for editing blocks in the program, not the HW config. Only one user can edit a block at a time.
https://support.industry.siemens.com/cs/us/en/view/45531110
SHort version is you need to have Step 7 on your file server, and then change a setting in: Start > Simatic > STEP 7 > Configure SIMATIC Workstation. Then your S7 install more or less asks the other step 7 install permission to access it's project.
Hello Guys, I have tried the programming but can't twist my mind to make it work correctly. I'm using S71200 and TIA Portal. My system has...
208
Kindly, we connected electrical power, 3x380 vac, between a supply station and an electric cabinet, away 180 meters. The calculation software...
854
im new at Allen bradley rslogix programming; i have something to ask you guys , and i will be happy to get answers so thank you in advance. when...
594
Hi all, We had three drives fail upon power up. The two had F081 fault code. The maintenance personnel attempted to copy VFD parameters using a...
1,551
Monday, we had a VFD that controls the spped of a conveyor belt fail on us. Took the replacement out of the box, installed it and bam, it failed...
37
16,874
