TI PLC Manuals
I'm looking for the programming instruction set. It's been 15 years since I've touched a 510 and I've forgotten most of the programming instructions through the HHP.
str(store) out and or strnot andnot ornot outnot andstr orstr
tmr(two line, units of 16.67ms, single output, internal (C) or external (Y))
udc(up down counter, 3 line, top line up cnt, middle line down cnt, bottom enable, single output C or Y)
drm(timed event drum, two line, top starts and stops drum. Bottom line when closed enables. Drum controls 15 outputs, internal (C) or external (Y). The drum has 16 steps, drum stays at each step for a programmed time. A value of 1=16.67ms. At each step, each of the outputs can be programmed to be on or off)
jmp#(jump, #=1 to 8) jme# (#=1 to 8) mcr#(#=1 to 8) mcre#(#1 to 8)
256 words of memory
64 internal relays, 1/2 of them retentive
16 timers/counters total
4 drum timers
12 inputs (X)
8 outputs (Y)
Hope this helps.
As a side note, we still have a few of these units running production.
Old post
I KNOW THIS IS AN OLD POST.
It just helped me with a program conversion that I don't have any software for, but I do have a mnemonic printout.
Thanks bluebyu
I think it's really tedious to dig through long manuals so I made an AI tool that can: - Answer questions about parts without digging through...
1,739
Does anyone have a good IEC IL and ST manual/tutorial. For Mitsubishi Q series if that makes a diference.
1,559
Help Please, Does anyone know where I can find, the manuals for PLC Gould A185, and programmer P110. I searched online for days without any...
3,007
I am new with PLC's. I have studied slc 500 programming but I need AB plc to modem communications student manuals. I am willing to purchase one or...
2,435
Does anyone know where I can find PDF versions of manuals for the TI-510 and TI-100 PLCs?
1,692
