TI series 500 controller
plctech187
Dec 2007
nc
Hi all my first post here, well i have a TI 520c-1102 which lost its program and i have been ask to reload the program but i do not have a cable does anyone have a pinout from the pc to the controller
thank you
I use 505-1102's. This is the cable config I use. It might help you. I tried to draw it below. The connectors are both 9 pin d-sub females.
1&6 <---------> 4
4 <---------> 1&6
5 <---------> 5
2 <---------> 3
3 <---------> 2
7&8 xxxxxxxxx 7&8 No connection between connectors, 7 tied to 8 at each end.
pins 9 - n.c.
This might not be the exact model, maybe it will help.
Link to manual, see page 3-28, table 3-1 for pinouts, and figure 3-3 on page 3-8 for baud rates and other stuff:
http://support.automation.siemens.com/US/llisapi.dll/17518915?func=ll&objId=17518915&objAction=csView&caller=view&nodeid0=10805067&lang=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=US&load=content&start=41&subtype=133300
plctech187 said:
thank you
Instruments Series 500 Controller 530T-1104 Could anyone help!! I have a 3 Series 500 Controllers that require a routine battery change. The...
5,500
Anyone who can Help. We recently purchased two injection molding machines that have TI Series 500 - 530T-1112 PLC cards. These are my first...
3,891
I have an older model Texas Instruments 500 Series Controller (not the newer 505 series) of which I do not have a backup of the logic. It appears...
6,493
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
285
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
121
