TI505 Profibus DP to AB 1794-APBDPV1
glesniak
Nov 2009
Yakima, WA
Does anyone have any experience connecting a TI545 to AB 1794-APBDPV1 Flex I/O Profibus interface? I am getting communication errors when I try to interface the PLC to the I/O. The rack consists of a 1794-APBDPV1 and two 1794-IE8 modules. Both the status light and comm light is flashing red.
Configuration of the ComProfibus configuration seemed easy enough and the addition to the PLC program was not an issue. The existing I/O on the network is working fine although they are Siemens ET200M I/O.
Are there any tricks one of you may have picked up to make this setup work?
I have used that combination in the past with minimal problems. Its been awhile but a couple of things come to mind. Are the thumb wheel switches on the Flex I/O module set to the correct Profibus address? Is this node on the end of the Profibus network? If it is do you have it terminated with an active termination? I recall once having an issue when the 1794 was on the end of the network run. I changed it to the middle of the run and it was fine. I also only ran the Profibus at 3MB. Does the Profibus status in Workshop show that node as online or offline.
Hi The project I am working on has purchased a 555 processor (actually the new CTI 2500 -300 CPU) and all the IO is to be profibus - of the...
2,245
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,279
Hello everyone, this is a noob speaking. I have no idea about plc's, just some basic things. So, I work at a factory in greece and we have a...
1,155
I am trying to figure out the math with two U16 values that are converted to a Float(F32) in the TI so as to duplicate in a Siemens S7-1500. Seems...
2,099
Stick a fork in it? Circa 1995 control system on a critical machine. Less than 100 Digital IO, less than 10 analog IO. I believe we can remove...
1,675
