Ti505 series, update clock via ladder logic
Dravik
Jun 2008
New York
1,650
Hello:
I'm working on a way to get several of our Ti545 plcs clocks sync'd with each other. Not looking for anything more than ~1 hour of each other generally.
I see that stw223,224,225 hold the current time/day, not having a test plc handy today I was wondering if anyone else had done this and could offer some pointers.
Thanks,
Mike
I would not use those status words if I were you, from the reference manual:
STW223 and STW224 contain a 32-bit binary representation of the relative
millisecond of the current day. STW225 contains a 16-bit binary
representation of the current day relative to 1-January-1984, (day 0). See
also the following description of Time-of-Day Status for STW226.
You should use STW141-144 instead, just remember the data is in BCD format.
Do you have a copy of the programming reference manual?
http://www2.sea.siemens.com/NR/rdonlyres/0BC627EF-737A-46E5-99F5-2BDF53884C5B/0/50582042.pdf
If I were you, I would use a Special Function Program for this application, and call it once an hour or so.
Might be easier to have a PC sync all the PLC's, with the PC being the master time keeper.
Ken:
Yes I have a copy of the manual, mine is a bit newer and I glossed over the odler status words. thanks!
I'm probably going to use Kepware and one of the FactorySQL installs I have around here to poke the values in. I'll do a quick write up if it works.
Thanks,
Mike
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,279
Hello everyone, this is a noob speaking. I have no idea about plc's, just some basic things. So, I work at a factory in greece and we have a...
1,155
I am trying to figure out the math with two U16 values that are converted to a Float(F32) in the TI so as to duplicate in a Siemens S7-1500. Seems...
2,101
Stick a fork in it? Circa 1995 control system on a critical machine. Less than 100 Digital IO, less than 10 analog IO. I believe we can remove...
1,675
Hi, I'm in an plant that uses TI505's. They have started upgrading to compactlogix but have reached the stage that they need PLC to PLC coms. TI...
2,350
