TIA link with HMI tags lost ?
userxyz
May 2002
any
2,768
I work in an integrated project with a TP900 panel and a 315 2PN CPU.
In a structured DB I added some adresses. Now when compiling I get errors (Invalid symbol assignment for tag 'STD ...'). I tried to reconnect, but that didn 't do the trick..
Do you guys have an idea ?
Thanks in advance,
Kind regards,
G
Found
Found the problem,
Because the S7 program was not yet compiled and downloaded, the Panel refused to startup.
Regards,
G
The solution from Ta2Mix actually works.
I had many tags with the error - Invalid symbol assignment for tag 'XXX' -
Choosing something greater than 100ms for the cycle time will fix the error.
Then, once compiled without error, it is well possible to fall back to 100ms, and compile again without error.
I have no idea what's happening there....
I've been trying to get some data out of IO-link devices, just for my own curiosity. Tools: Siemens ET200SP CPU Siemens CM 4x IO-Link Keyence...
193
Has anyone got any experience with Ethernet-mpi IBHlink & tia portal 14 or newer I have it working fine in simatic manager but in tia, although...
1,934
Hi, has anyone had experience setting up the hardware config for the these balluf blocks? I have the GSD file installed but unlike S7 classic I...
2,823
Got a service request answered from Siemens and it was a big surprise to me!! My task was to configure the 4SI IO-Link module with IM 151-8 PN/DP...
5,737
I have been trying to connect my IM 151-8 PN/DP CPU over PROFINET in TIA Portal V11 and was able to Flash the LED and start the online...
6,892
