TIA portal and PLC SIM
rQx
Oct 2010
Trelleborg
1,051
Hi!
I've never tried PLC SIM and wanted to give it a try now when I got v14. I have all installed and updated to the latest version. s7-1200 fw 4.1 in project.
I press start simulation, and things start to happen but when I press download it only say "error downloading to module". I know I was ignorant thinking it would be so straight forward. Anyone has any suggestion on what might be wrong?
/Tim
PLCsim V14 does not work in Windows 10 for S7-1200. It works for S7-1500 & ET200sp CPUs.
TIA portal V14 is not officially compliant with Windows 10. This will come with SP1 in the summer of '17.
I had the same problem in December and after my research I cam to the conclusions and answers above.
I had to install V14 in Windows 7 VM.
Another bug I found is this (not related to the version of Windows):
http://www.plctalk.net/qanda/showthread.php?p=717291
Regards
Thanks for your reply. I'm running Windows 8.1 though, but maybe same problem here?
/Tim
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
35
281
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
328
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
348
Hello everyone I am learning to program Siemens controllers in Tia Portal. I would have a question for you present on the forum. Would any of you...
4,472
