Tia Portal plc code
PLC Code- CIP Station
Hello everyone
I decided to rewrite my code according to your suggestions.
Each of you colleagues gave me some tips.
I created FB and Array ( it also helps in HMI with multiplexing).I think it made my code clearer.
I will add that I define the names of variables clearly and in Polish.
Now I am at the stage of writing permissions to perform a specific function, e.g. start, stop, pause, errors and power back supply (in one FC).
I will try not to use set, reset.
Then I think that after meeting these conditions I will have a CALL of a specific washing function: alkaline washing, acid washing and disinfection.
It seems to me that the best will be to meet the conditions and CALL of a specific FC in which there will be a separate type of washing.
I just don't know if that's the right approach.
I would like to ask you to evaluate my code and hints if I understood your hints correctly.
https://drive.google.com/file/d/1PjudnUbnTnZXWaRYr3w5ANCjz1ZN4-rI/view?usp=sharing
Thanks for your time and any replies.
260
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
312
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
345
Looking for a way to export PLC status to Kepware ultimately. In Rockwell we can do a GSV and get a lot of information about the PLC. Is there...
1,568
Hi Experts, Good day! We've encountered an error while uploading the program from S7-400PLC using TIA Portal software and try all the TIA...
3,547
