Uploading S7-400 PLC (HW and SW) using TIA Portal
EMENDOZA
May 2021
Binangonan Rizal
Hi Experts,
Good day!
We've encountered an error while uploading the program from S7-400PLC using TIA Portal software and try all the TIA versions from 12 to 16.
By selecting "Upload device as a new station (hardware and software), it continues the process of uploading, after a couple of seconds an error message pop-up "Totally Integrated Automation portal has encountered a problem and need to close". I'm still trying to get the diagnostics messages to the customer.
On the actual hardware, the PLC CPU is S7-400 while the IOs are FESTO brand.
Is there will be an error upload if I don't have the GSD file for the said IO.
I have no actual experience with S7-400 in combination with TIA.
I do know that a program made with TIA and loaded in an S7-300 or S7-400 cannot be uploaded with STEP7 Classic.
I suspect that it is the same limitation in the opposite direction.
I suspect that you can only take an offline S7-300/400 program, convert it to TIA, and then load it in the PLC.
I would not use TIA in combination with S7-300 or S7-400.
Try to upload with STEP7 Classic.
Hi Jesper,
Thanks for your response.
We try to upload it using Step7 Classic. There's a pop-up error message "The HW configuration was created with a newer version of STEP 7 on the basis of the TIA Portal. The loading to PG will be canceled."
Are you using the Bridged Adapter network setting in the VM settings, with a static IP address set in Windows?
Hi sigma,
With all due respect. If your concern is with the connection from PLC to PG, it's connected. I can see the S7-400 PC from the "accessible nodes", the process of uploading continues.
Hi guys, I can't quite figure out how to upload a new program to the ML1400 that I'm working with. Every time I try to upload a code I've been...
1,785
Hi guys, I am caught in a situation where I have no choice but to do a upload. This is what I get from the help file: Restrictions when...
4,387
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
136
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
302
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
175
