TIA portal & Cp340 RSR232 function blocks
Ingis
Aug 2013
Oost-vlaanderen
34
Hallo,
I have Tia Portal V16 and I'm upgrading an older machine.
That machine has a component running on rs232. The machine has still the old I/o cards on an ET200 profibus island connect to a new plc.
The rsr232 is through CP 340 RS232C.
I want to read/write ofcourse. Would be nice to dumb the data in a DB.
I'm reading manuals/internet posts... and the tell me to use the FB 2
P_RCV and FB 3 P_SEND blocks.
they should be under instructions -> communication -> ptp-coupling:cp340 ... but those instructions are not there anymore?
I have a receive_p2p and a send_p2p instruction under the ptp instruction folder, but i don't have a lot of luck with using that one.
some has an idea?
best regards,
Wesley
Its a total new project.
Only the old i/o cards are being reused.
Its a new S7-1500 plc (1513-1) connected with profibus to ET200 i/o islands. On one island I have the cp340 rs232 card.
I can find the card in my hardware list in tia portal. I can add it to my rack, no errors. But I can't find the normal corresponding building blocks in my instructions.
thanks for the answer.
the 'slave' island has a IM 153-1, for ET 200M card, next to it is the CP 340 RS232C card after that some DI/DO cards.
If I understand you correctly I need to use the et200 instructions to work with the cp 340 card?
Can you control CPs in remote ET200m racks? I thought they used a part of the backplane that only exists in central racks, not via IMs.
My bad, I assumed the island was ET200S, now OP has clarified it is ET200M my posts are not relevant.
258
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
210
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
176
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
312
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
447
