TIA Portal v11 and MP377 simulator
dbozic
Oct 2013
Zagreb
74
Hi to all reading this!
I am having problem with my project. I'm working on the TIA Portal V11 and I successfully simulated my program (plc s7-300) with plcsim and basic panel(KTP1000). I need to change the panel to MP377 and try to simulate it. The problem is, start simulation option on the hmi is grayed out. I noticed that all multipanels are grayed out, so I'm curious whether I'm missing something that i cannot find, or starting simulation isn't that simple as in basic panels.
Thanks for your help in advance!
maybe MP377 (and multipanels) are not allowed with basic TIA (don't know which version you have). certain panels need higher licences, like wincc comfort, advanced and pro
Thanks for the reply.
Forgot to mention installed software versions:
TIA Portal: Version V11 SP2 Update 5
Step7 Professional Version V11 SP2 Update 5
Wincc Professional Version V11 SP2 Update 5
I managed to simulate panel over Wincc Flexible Advanced 2008 but I'm still curious why the TIA portal simulation isn't enabled. It would be much easier to work with all in TIA directly.
Hi all, I'm a bit of a noob with Siemens. (I know enough to be dangerous) I've come across a V11 offline program that doesn't match the online...
1,649
Hi, Yesterday I decided to try to download a program to device using my virtual machine which runs Windows 7 Professional and TIA PORTAL V11...
5,575
I am trying to get a tia portal v11 application to run and the software is telling me to install wincc basic v11 update 2 and wincc comfort v11...
4,105
I have a tia portal application programmed in ver 11, but when I try to open the application it says its missing v11 update 2, I downloaded and...
2,817
Hi all and Merry Christmas. I am running TIA Portal V11 with SP2 and UPDP5. I am only running 2 machines with this software right now and...
2,713
