tia portal v11 vs step 7 5.5
google08
Jun 2011
Kiruna
51
Is Tia portal v11 newer version of step 7 5.5 . I am just on
mine way to learn how step 7 5.5 work should i discard it and
learn the new program Tia portal v11?
What program u guys think its good to learn Win flexible,
WinCC step 7 or Tia portal or learn them all? its alot of
information about each program, should an automation enigneer
have to know them all?
Personally, as a SIMATIC user for 25+ years, I've learned not to adopt new application software from Siemens too early.
I'll be sticking with S7 V5.5 and various flavors of WinCC etc. until either TIA Portal gets another couple of SP's under its' belt or I'm forced there by hardware releases.
There are already HMI's on the market that are 'portal' only.
I think by this time next year Siemens will be 'gently persuading' their customer base to change to the new programming platform by making all new hardware portal only.
I've had a quick look at Portal and, while there are some improvements, I don't see it as any major leap forward. The screen is very cluttered with the WinCC Flex GUI that they seem to have based it all on. This isn't too bad on a PC but on a laptop (with a smaller screen) it's going to be less pleasant to use.
However, saying all that, it's easy to dismiss new products because they are new and unfamiliar. When I've delved a bit more into Portal and got a bit more confident it may be the best thing since sliced bread.
To the Original Poster, my advice would be to learn v5.5, WinCC Flex 2008. If you need to learn WinCC (i.e. the SCADA software) then do it, if not, then just leave that alone.
If you just jump straight in to learn Portal at this stage you may end up being a bit 'before your time' unless your place of work is very quick to adopt new technologies.
Hi all, I'm a bit of a noob with Siemens. (I know enough to be dangerous) I've come across a V11 offline program that doesn't match the online...
1,647
Hi, Yesterday I decided to try to download a program to device using my virtual machine which runs Windows 7 Professional and TIA PORTAL V11...
5,568
I am trying to get a tia portal v11 application to run and the software is telling me to install wincc basic v11 update 2 and wincc comfort v11...
4,098
I have a tia portal application programmed in ver 11, but when I try to open the application it says its missing v11 update 2, I downloaded and...
2,802
Hi all and Merry Christmas. I am running TIA Portal V11 with SP2 and UPDP5. I am only running 2 machines with this software right now and...
2,707
