TIA Portal YYYYMMDD to Date or DTL
JohanM
Sep 2015
Terchová
53
Hi guys
I am crossing internet two days, but I can not find something really helpful for me..
I have this problem:
I have to read expiration date from EKS key and compare it with actual PLC date. That date in EKS is coded to 8 bytes character by character YYYYMMDD..I can read that bytes, I can convert it from ASCII, but I dont know, how to convert it to Date format or DTL.. Can someone help me with this? 🤞🏻
There are many ways to do this, but you could convert the parts of the input string to internal DTL formats and convert again to date-format in order to compare YYYYMMDD.
String conversion can be a bit troublesome, but it's doable.
I have a working solution, but try it yourself first.
Here's a hint:
(*Convert string to UINT (.Year datatype). Input the 4 Chars (L) starting from char 1 (P)*)
#TestDTL.YEAR := STRING_TO_UINT(IN := MID(IN := #InputDate, L := 4, P := 1));
Since you have the bytes char by char, you probably have an Array[0..7] of CHAR that you can convert with CHARS_TO_STRG. Either to one complete string[8] or 3 separate strings for year, month, and day. After that you can convert to UINT/USINT.
Since you'll (probably) read the system time with RD_SYS_T or RD_LOC_T you'll have your current date in DTL format. Convert it to DATE with DTL_TO_DATE before you compare, otherwise you'll also compare the time of day, when you are only interested in the date.
You could also compare your CurrentDTL.Year with your TestDTL.Year and so on with .Month and .Day. You'll save a few conversions that way, but will do several comparisons instead.
OR you could also convert your CurrentDTL to strings and compare the other way around, but then you'll have to do padding with leading zeros for the month and day.
As you see, there are many ways to do it :)
Thank you my friend!
I got solution from huggy_1 from Siemens forum. It is basicly what you suggested to me. Many thanks to you guys!🍻
FUNCTION "EKS_DateToDTL" : Void
TITLE = EKS Date to DTL
{ S7_Optimized_Access := 'TRUE' }
AUTHOR : huggy_d1
FAMILY : EKS
VERSION : 0.1
//Accept EKS Date char array [YYYYMMDD] as input
//Output EKS Date as DTL tag
VAR_INPUT
EKS_Date : Array[0..7] of Char;
END_VAR
VAR_OUTPUT
EKS_DTL {OriginalPartName := 'DTL'; LibVersion := '1.0'} : DTL;
END_VAR
VAR_TEMP
EKS_String : String[8];
yyyy_string : String[4];
mm_string : String[2];
dd_string : String[2];
END_VAR
BEGIN
// convert YYYMMDD ASCII char array into a string
Chars_TO_Strg(Chars:=#EKS_Date,
pChars:=0,
Cnt:=8,
Strg=>#EKS_String);
// parse EKS_string to obtain YYYY, MM, DD as strings
#yyyy_string := LEFT(IN := #EKS_String, L := 4);
#mm_string := MID(IN := #EKS_String, L := 2, P := 5);
#dd_string := RIGHT(IN := #EKS_String, L := 2);
#EKS_DTL.YEAR := STRING_TO_UINT(IN:=#yyyy_string);
#EKS_DTL.MONTH := STRING_TO_USINT(IN:=#mm_string);
#EKS_DTL.DAY := STRING_TO_USINT(IN:=#dd_string);
END_FUNCTION
253
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
208
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
174
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
447
