Time entry from HMI compared against curr_hour and curr_minute
PFrog
Apr 2011
Ohio
83
Hello,
I am going to use an HMI for a 4 digit military rime entry. I want to compare this value against the curr_hour and curr_minute in the control logix processor. My question is how to break up the 4 digit number with the two upper, and two lower values that I can use to directly compare against curr_hour and curr_minute?
I could have two different entries on the HMI to accomplish this, but I liked the idea of just having one.
I am using Rslogix 5000 with structured text.
Thanks!
use a GSV to put the time into tags, then compare as normal
I am using a GSV to pull the system time from the control logix processor. I am looking to compare those values against a 4 digit military time entry from an HMI. I am wanting to know the best way to break up the 4 digit time entry with the two upper digits comparing against the current hour (from the GSV) and the two lower digits comparing against the current minute (from the GSV). I am not certain on how to separate the 4 digit number...
Check that the division works with minutes over 50. If not do the mod first then subtract the extracted minutes from the total before dividing by 100.
I have a colleague working on a system with a Siemens S7-1500 PLC, a Siemens TP1200 Comfort HMI programmed using TIA Portal V15.1. He is trying...
3,247
Hello, again ... I'm working with a Micrologix 1200 with RTC module and a PanelView Component C400. I've created the interface and logic to...
1,481
Need Help. I need to add an entry field to a PV1000 to record product lot #. The field is 8 characters long, all numeric. The max numeric value...
3,386
Hi We have key operated selection switch in a panel on which HMI(MP277) is also mounted. Is it possible that when this selection switch is in OFF...
6,976
Hi everybody, I have about three Red Lion HMI's, the calibration on the screens seems correct but where I'm using the pop up keypad to enter...
117
