Timed interrupts - anyone??
Preeya
Nov 2003
112
Hi everyone, I need to program an S7 200 for high speed application. As the S7 200 has only 2 timers on the ms resolution, I plan to use timed interrupts. But I don't quiet frankly understand their operations.
To what I understand, when the timed interrupt is enabled (through an event) it executes the interrupt program for specified time and comes back to the main program. So does this mean if I switch on an output on the interrupt program, will it become off after the specified time.
Please someone help me! Thanks!
Maybe there are some interrupt OB??-program for specified interrupt time. You need load Pheripherial to process image in this OB??-task.
or
You can do something in OB1-program where you call your sub-routine time to time, where are pheripherial loads to process image etc.
I hope this help somehow.
HI can somebody explain STI preferably with example thanks a lot
7,291
Good afternoon all I'm a bit puzzled. 19 inch AB HMI. addressed 192.168.1.22. laptop 192.168.1.10. I can see it in Linx. I can download .mer to...
628
Hello All! First Post! What is the "Timed Out" Check Box used for on the MSG instruction in Logix5000? This check box is located under the...
1,866
Today when an operator went to start a piece of equipment that gets infrequent use they got a bunch of time out errors. Multiple errors saying...
5,638
Hello, I've done several migrations from SLC 5/05's to 5370 L33ER Compactlogix controllers. I've just encountered my first PID instructions with...
1,695
