Timed permissive ?
Snap25
Dec 2014
Michigan
237
On one of our conveyors we have a height verification sensor that is triggered by a photo eye as product passes by. QA wants another sensor to take snapshot of the temperature as well. Due to a lack of places to mount the sensor I had to put it 10 inch’s diwn the line and using a separate sensor to grab the anal value in the plc.
If the first validation check fails, I want to pass on that particular item on the second sensor. I don’t want to log 2 failed products if 1 item fails both validation points.
As product fails the first check, it’s very likely that a passed item is going through the second check point and possibly another item inbetween the too points.
As is, is my best option to time up when to ignore check B if check A fails?
I would set up an array to capture the first test and as the items pass the second sensor for testing remove it from the array. It would be a FIFO setup in the plc. Using timing can cause a number of other issues if there is any difference in spacing of the product on the belt or the belt changes speed for any reason. It is always a better idea to find other ways to handle the situation.
Is it possible to use something like a barcode scanner or RFID to uniquely identify each part? Then the usual track and trace stuff kicks in where you can have an array, and record each pass/fail for each part in a big array.
You could use a bit shift and load a "1" at the first position if height is okay and a "0" if it isn't. Run the bit shift on a timed pulse only if the conveyor is moving. If you get a "0" at the second position, then ignore the temperature reading.
Thanks for the suggestion. I'm going to try a few file/shift instructions in an emulator tonight.
+1 for the Bit Shift. It's easy to understand, and Bubba won't call you at 2am because it doesn't work.
Bubba.
I agree. I've been using it in my emulator, seems pretty basic.
Eventually, they are going to add a rejection system as well. If Check A passes and sends a 0 down the array, is there a way to have Check B place a 1 in the array? Or do set up two separate cascading arrays?
Good afternoon all I'm a bit puzzled. 19 inch AB HMI. addressed 192.168.1.22. laptop 192.168.1.10. I can see it in Linx. I can download .mer to...
628
Hello All! First Post! What is the "Timed Out" Check Box used for on the MSG instruction in Logix5000? This check box is located under the...
1,867
Today when an operator went to start a piece of equipment that gets infrequent use they got a bunch of time out errors. Multiple errors saying...
5,639
Hello, I've done several migrations from SLC 5/05's to 5370 L33ER Compactlogix controllers. I've just encountered my first PID instructions with...
1,696
From what I can tell the STI timed interrupt in 500 is a real hardware interrupt, correct me if I'm mistaken. I currently use this for exact...
5,366
