Jon82387
Hi all, trying to something fairly simple but seem to be running into an issue with trying to get my timers to reset..... if i run the program in rs500 emulate it seems to work... but when i try and toggle/actually test on the ML1400 processor it doesn't work or reset.
Theory is i have two photoeyes PE1/PE2. PE1 will be used to flag an input and start a small conveyor belt. PE2 will be maybe 20' away and will be used to stop the belt or put it to sleep when no input has changed for say 6 minutes.
So i'm latching the motor on with PE1 and sleeping/stopping with PE2. Issue arrises when i try to restart the motor after it has went to sleep/stopped and say something flags PE1 it will not reset the sleep timers.
Looking for some advice on this.
Thanks!
Jon
Thanks!
Jon
