To setup parameter for master cc link
fengkong
May 2006
Malaysia
Dear Members, now I'm working with Mitsubishi PLC QO2HCPU and Master CC link QJ65BT11N, Initially I'm already transfer all the network parameters from GX delevoper software to QO2HCPU, but When I'm try to edit the network parameter and sent the new setting to QO2HCPU I'm got message from software "the parameter exist in the QO2HCPU being edited and discard the being edited and close the window" when i select NO, no transfer will be made to QO2HCPU but if i select YES, there have a transfered but not the new setting for network parameter. It seem, the existing network parameter setting in CPU cannot to be modified or transfer the new setting. So, what i must do to set up the new network parameter setting and discard the old setting???...
Hello all, I'm currently using TIA Portal v17 with a S7-1200 and a KTP-400 Basic HMI. I have a data log set up that begins logging various data...
1,203
can i configure and monitor the parameter of pf 4m via plc or scada if we can then how and what software and hardware are required for that if not...
3,036
<Citect> Computer Setup Editor - Search parameter reference returns nothing, why? As above. Anyone can help?
1,589
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
67
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
86
