[Topic (read)] Connection between Glofa G7m LS PLC and WinCC Flex
amr.elsebaye
Sep 2015
KSA
Hi all,
I wanna Connect Glofa G7m LS PLC to WinCC Flex
i have no Serial port in my laptop so i use USB to serial converter and cable Rs232( 3wires 2,3,5 pins), it works well with the GWIN program but not work with WinCC.
i try also to use cable Rs232 from Siemens Catalog(see attached RS232 ) but it make the PLC completely stopped.
i use the loader port for the PLC without using any Extension connection modules.
i Also try to use internal C-net protocol of G7m PLC by making Switch Position (On)(see attached G7m )and use the connection (see attached RA422/RS485) it works but very very bad,get error messages and doesn't monitor the output.
Please help
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,893
HI, im a student and never experience changing PLC battery. i have some questions in mind. 1. how will i know if the battery is low or it...
3,056
I'm sorry to bother you all with this post as it is off topic but Im sure somebody here could help me. I do use PLC'S and have found this site...
6,238
GAS WAR - an idea that WILL work. This was originally sent by a retired Coca Cola executive. It came from one of his engineer buddies who retired...
89
22,232
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
295
