torque history data in servo motion control?
unsaint32
Oct 2012
minneapolis
365
I'm a maintenance person at a factory. We have a following setup; Controllogix5000 1756 L61 with Kinetix 6500 thru Sercos card. Our axis suffered bent shaft few times last week. We have consultant programmers and they are not readily available for questions.
I can navigate through Controllogix5000 okay except the motion instruction part. Can you guide me to where I can find any data on torque? Is there somewhere in the program that I can look for the torque history of a certain axis?
Thanks.
The ControLogix does not control the torque directly. If this data is available then you must use a get system variable command to get the torque from the Kinetix 6500.
If I use the GSV command, would I get the last value? Or does Kinetix 6500 hold hitory (or trend) of such data collected over time?
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
91
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
274
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
446
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
529
Hello, I am posting this question (regarding drive control) on this PLC forum because I see that there has been discussion regarding this issue...
617
