Torque Required - Physics Help
Timeismoney08
Jul 2012
United States
312
I have a small application where I need to spec out an actuator.
The load is 7kg and needs to move 90 degrees around a 1cm diameter in 1 second. What is the torque required to achieve this?
Can someone help me work out the physics here?
Thanks for the help!
F = m * A
Force equals mass times acceleration; it really is that simple.
You know the mass; 7 kilograms.
When you say "move 90 degrees in 1 second" do you mean that it needs to start, move 90 degrees, and stop in 1 second ?
A one centimeter torque arm seems unusually short, unless this is a long cylindrical load. Can you describe it in more detail ?
An arc of 90 degrees with a radius of 1 centimeter is (pi * 2 cm / 4) = 1.57 cm.
So you have to accelerate to get to 7.85 mm in 500 ms.
Distance traveled under constant acceleration is straightforward: s = 1/2 a * t^2.
.00785 meters = 1/2 * acceleration * (0.5 seconds)^2
Acceleration = 0.0628 meters/sec2
Because we know the mass and acceleration, we can calculate the linear force:
F = m * a = 7 kg * 0.0628 meters/sec2 = 0.4396 newtons.
With a torque arm of 0.01 meters, the torque required is 0.004396 newton-meters.
Thank you for the help.
The part is very close to on center of the rotary motion. It's rotating on a bearing and connected on the outside of the OD and driven by a rod.
I'm comfortable selecting actuators for linear applications, but just needed some help converting that to rotational motion.
Are you driving this load from a shaft at the center of rotation, or are you pushing on a rod that's connected to an arm ?
I may have been thinking about the load incorrectly. Explain more about the mechanism.
Pushing on an arm that rotates the bearing and part in the middle of the bearing.
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
91
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
271
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
445
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
524
Hello, I am posting this question (regarding drive control) on this PLC forum because I see that there has been discussion regarding this issue...
616
