Toshiba EX40+ & Hand Programmer
EwanS
Sep 2010
UK
First of all thanks for an informative site , Secondly I am a Newbie :lol:
Now the help part
Toshiba EX40+ PLC and Hand Programmer
1 - How long will logic exist in the memory of the battery goes flat ? - I assume none,
2 - I need the hand programmer user guide so I dont screw up - all I see when connected is the Run or Hold icons - nothing else - should I see anything else - and if so how can I check ?
Cheers
Ewan
This link has what you need, right click on link, then left click on Save As. Caution: large file, 13 megs.
Link:
http://www.toshiba.com/ind/data/tag_files/EX20_40%20Plus%20Manual_506.pdf
1. Probably about 5 minutes after powered down. I believe if you have a EEPROM plugged in, it will reload it upon power up, not sure about that. Page i-54 in the manual has more info about battery replacement.
2. See the link above.
Hi Guys, Does anyone know where I can buy, beg, borrow or steal a programming cable for the Toshiba EX40 plus PLC. I have suitable software, but...
2,099
Does anyone have the actual pinout of the Toshiba EX40 Plus / D100 Programming interface/connector RJ45 socket please? OR: Can anyone tell me...
4,122
Hi All Newbie here so please excuse any tech gaffs! I have been asked to look at copying a program from a faulty Toshiba EX40 to a new Unit as...
5,576
Hi, I'm looking for the user manual for the following PLC. Model number: EX40*4MCRD5 October, 1989. Edit: I've just found it! After a couple...
2,828
I have replaced a blown out program in an EX40. I have replaced the battery and restored operation. I wish to install the ROM module (RM66, with...
5,861
