Totalizer function block rs logix 5000
bfranklin
Sep 2012
Alberta
125
rs logix version 20
logix 5572 processor
function block currently configured"
operstartreq: always on
operstopreq: always off
operresetreq: every morning at 7 a reset happens.
I would like for the current day total to move into the "old total" in function block. There is an option in the parameters and I do have it checked but it does not seem to work.
What am I missing?
I'm not sure that I understand what you're trying to do - but here are some BASIC ideas ...
"Old Total" is an OUTPUT of the TOT (Totalizer) function block ... in simplest terms, whenever you do a "reset" to the totalizer, then (and only then) the value currently in "Total" gets moved into the "Old Total" location ... from there you could (if necessary) use it as an input signal for some other (separate) function block, etc. ...
in other words, the Totalizer "remembers" what the previous (OLD) total was – whenever you decide to reset the CURRENT total back to zero in order to start over again for the next session ...
I might be misreading what you've said, but basically checking a parameter off or on doesn't affect whether it "works" or not ... the check only decides whether the "pin" for that particular parameter will be visible on the function block display ...
suggestion: if this doesn't help, consider posting your ACD file (you'll have to zip it first – forum rule) ... tell us what you want to happen and we'll try to help you nail it down ...
good luck with your project ...
Thanks for your help.
Using the operator control options as your start, stop and reset doesn't hold your "old total"
Thanks again.
you're welcome ...
using the operator control options as your start, stop and reset doesn't hold your "old total"
I'm not sure that I fully understand that statement – so I'll just assume (gosh, I hate that word) that you're making headway – and that all is either now well - or at least getting better ...
just for discussion – there are TWO basic ways to control the Totalizer:
(1) using "Program" control ... and
(2) using "Operator" control ...
most systems that I've seen prefer to stick with the "Program" control method – and just leave the "Operator" control method on the shelf ... that's the way I set mine up in the example that I posted earlier ...
Thanks again.
and again, you're quite welcome ... I hope that I've been helpful ... if you still need more help just post your file ... we'll try again ...
Attached is what I had previously set up before you advice. The total is current days with nothing in the "old total" from yesterday.
try adding a "one-shot" action to the Reset Request ... it's working on my system ...
unless you have some valid reason to do otherwise, I recommend that you stay with "Program" control - and not even use "Operator" control ... it usually makes life simpler that way ...
I am trying to setup the TOT function block so that I bring in GPM and want to output MGD. I cannot seem to figure out the correct gain in the...
2,716
Greetings, this is the first FB programming I've done. It is running a totalizer from a flow transmitter. the routine is being jumped to...
25
5,200
In a distillation column application a control valve opens to remove distillate product and closes to return reflux. Cycle_Period timer is set for...
11,652
Hello!!! This is my first post. Im triying to configure a Totalizer function block on RSLogix5000. I want to know the correct parameters settings...
5,573
Dear all, I am having a flow totalizer that reset automatically every Thursday at 6:00 am. I would like to stack and save the value of the...
2,795
