Totalizing flow rate: analog vs pulse - a comparison
danw
Oct 2004
midwest, USA
3,427
Given the variety of opinions about the wisdom and feasability of totalizing an analog flow signal I ran a test by totalizing both the analog flow rate signal and a pulse output from a magnetic flow meter in a standalone recorder.
For those devices, the result had a remarkably small error.
If you're interested in the details, the write-up is on the company blog:
http://blog.lesman.com/2012/04/18/f...vs-pulse-input-totalizer-comparison/#more-638
Dan
We currently have 2 system measuring a liquid similar to water. Density is around 8.3lbs/gal. We take the flow in lbs/min and calculate lbs per...
4,014
Hi everyone this is my first post here. I have been reading a lot of the posts here regarding totalizing using pulses, however not exactly what I...
2,864
Can someone tell me if this math function is correct to totalize analog flow in a 30 Milsec peridoc task...
1,737
AB SLC 5/05 RS logix 8.40 I have two existing flow totalizers on site that are currently reading 300000 m3 and the other around 70000 m3. These...
1,979
HEY, I am pulling flow data from a Prosoft MVI46 MCM into a SLC 505 and need to totalize the flow daily in cubic meters use an analog value. I...
1,803
