Totalizing Analog flow in Contrologix.
bobwithdana
Dec 2003
california
239
Can someone tell me if this math function is correct to totalize analog flow in a 30 Milsec peridoc task?
FT_TC08_01.SCALED/2000+XC_TC08_10.FLOW_TOTAL
If true what is the relationship between 30 Milsec and /2000?
Thanks so much?
Hello,
I am confused. What is the input flow rate time base? per second? minute? hour?
Hello,
I would assume the flow rate is per minute.
60 / 2000 = 0.03 = 30 mills
I could be wrong.
Given the variety of opinions about the wisdom and feasability of totalizing an analog flow signal I ran a test by totalizing both the analog flow...
3,426
Hello, I am using an A-B micro830 PLC and analog input plug-in with Connected Components Workbench 3. I have a flow meter sending a 0-5V analog...
3,423
I have a Mitsubishi Q Series PLC and a E-terminal. I have an analog from a magometer 4-20ma going into my plc. I just need the PLC to read the...
2,589
Hello everyone! I've got something I'm trying to figure out and I'm possibly overthinking it. I've got a 25,000 gallon bulk chemical tank with an...
2,179
Hello, all. I’ve worked with totalizers based on a flow meter. However, I am trying to use ladder logic on totalizing a tank based on volume. I...
1,135
