Transducer Shopping
The tank system consists of a small pipe (copper) running to each tank.
In the control room there are a (electric/manual)valves, for each tank one.
There is a simple gauge next to this, or a pressure sensor.
Now you connect one tank and the compressor blows out the air for 2 seconds, then the gauge can be read.
The pressure is related to the height and the density.
Old units had a book with the densities for each tank apart, as it can be sweet/salt water or HFO, Diesel.
Also a tank table with heights and volume was needed as each tank has a different shape (Due to the position of the ship it has many columns to get the correct port/starboard and draft.
Now adays it is fully computerised.
The last one i made was for fish tanks on a trawler, as the old system was not good in seawater and they used a plate before the sensor, however the fishrests were behind this screen blocking the correct working.
Brewershardware.com has 2" tri clamp to 1/4" NPT fittings for 18$ if that helps.
The installation of a seal on an instrument requires evacuation of the pressure volume with a vacuum pump and then backfilling with a suitable fill fluid without allowing a remaining air pocket in the closed pressure system. Seal filling is not rocket science, but it does require equipment and skill.
Hi all, I have a AC current transducer that I want to bench test to ensure I am getting a 4-20mA output. I am using a AE001 unit. It is very...
121
I have a set of these: https://www.i-s.gr/files/ND%20Clamp-on%20CT%20Brochure.pdf Specifically M1.UM which outputs Voltage. I am looking to use...
679
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,098
Has any used a ballistic pressure transducer with a PLC? I am not sure if it will capture the event that I need to use as a control. The device...
1,088
I am updating controls on a leak tester, from a SLC 5/02 to Compact Logix. The SLC used a DDV instruction to help scale a differential pressure...
17
4,434
