Transfering from WinCC flex to MP377
Egil-s
Jul 2008
Norway
18
I have purchased a Siemens MP377 Panel and a CPU 314 with a couple of racks with modules.
My previous experience with panels is only a TP177 connected to a S7200.
I trying to transfer from WinCC flex to MP377 with a USB cabel, but cannot establish any connection.
Anyone else experienced this problem?
Regards Egil
Did u set the USB channel open in WIndows CE (on the MP377)
Regards Egil
Well, i didn't explain myself right there.
I use the same cabel as i use when i transfer from Step 7 too the plc.
Usb-Serial.
I use the RS 485 on the MP 377.
It's a USB-MPI converter ?
Usb-Serial.
Never tried to download with such thing.
What I do when downloading on a new panel is:
PG/PC interface, make the PC master, and check that the settings are the same as the panel.
On the panel, open the MPI channel and set an adress, if there was allready an adress, then change it.
Check in diagnostics if you can see the setted adress.
If you can't see it there, then you can never have a connection in wincc flex.
Keep searching for the prob then.
PS: I've noticed that some panels are never seen after an OS update if they are not in transfer mode, so set the panel also in transfer mode when looking in diagnostics.
Egil-s said:
That's right.
So if you are using MPI did you configure the HMI for MPI transfer in both the "S7-Transfer Settings" and the "Transfer" applets in the Control Panel of the MP377? Also, did you select MPI and the node address in the WinCC Flex transfer dialog?
Look for the usb drivers on the WinCC Flex install CD's
CD_3 > Support > DeviceDriver > USB
Hi all, I am using WinCC flexable v.2008 Sp2 and transfering project to a MP377 12" Touch HMI via mode ethernet / IP address. My issue is that...
1,545
AB 1200P 6181P Needing to transfer .cli file from one 1200P to another. I've loaded the file to the new one but it will not open. File name is KM...
1,290
Hi guys. I am using RS Studio v24 and I have a structure BOOL[2048] inside. When I give project to our HMI designer he sees that array of bools...
2,191
Hi, I've been trying to run my project in Simulation (and check display on VNC viewer). When I try to download a procjet to simulator, then I...
1,522
Hi All, I've recently gained control of an existing control system used for purifying water. We have an SLC 5/05 processor and are using RSView...
3,056
