Trend view TIA Portal - Extend time
For your reference, this forum post on WinCC flex 2008 http://www.plctalk.net/qanda/showthread.php?t=96524 will answer your question as they both use the same trend view. (TIA Portal is based on WinCC flex 2008, with some nasty exceptions.)
you have up to 999 trend values (properties tab, trend - where you set up the tags) which can be independently set up for each tag. This allows you to trend for up to 999 * sample time.
Anything more than that and you will need to use audit functions. The sample time is variable however so you could lower your sample rate to increase the time you can trend for.
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hello, i have a problem, i was trying to fix a trend that wasn't registering the tags, i got that fix by setting the path, but now i can get it to...
837
Hi guys, Is it possible to automatically generate PDF Report of Trend and Datalog in FactoryTalk View SE v12? If YES, Please, how?
683
Wondering if anyone can help me out with a couple FT View SE VBA questions regarding trends and local messages. 1. Is it possible to use the...
1,366
