Triac Output Module
feno
Jun 2007
Dublin
Hi all,
Great site and looking for some help.Doing my Electrician exams and PLC's are a topic on it.Heres an exam question from a past paper i cant find the answer to.Any help would be great!!
Q:
Explain the operation of a triac output module for a programmable controller and explain why the current drain must exceed its holding current.
If someone knows could they keep the answer somewhat condensed.
Many thanks,
Stephen
I'm not being brusque but, why don't you Google the following terms and see what you come up with?
1. triac
2. holding current
3. solid state relay
Ok, first you have to get a grasp of a thyrister, which is a gate that allows very high levels of current. A thryrister only allows current in one direction (anode to cathode) and that current must be high enough to cause a phenomenon called "avalanch current" or as you termed it "holding current". You will have to talk to a physicist if you want to know the reason for this particular behavior of free electrons. But basicly as I understand it you need a particular amount of positive voltage, and thus current, from anode to cathode in order to brake the valence or free electrons free in the material. For reasons totally beyond me the thryister will continue to conduct even after the gate voltage is taken away. That is until it is reverse biased with positive on the cathode and negative at the anode and the gate is turned off.
A triac is two thyristers pointing in opposite directions, one's anode to the other's cathode and visa versa (in parallel but opposite directions), but controlled with their bases or gates tied together as a single on/off control. So when the gate is turned on, one triac conducts during the positive half cycle and the other during the negative half cycle. When it is off it acts as a perfect insulator.
So in short and in answer to...
"Q:
Explain the operation of a triac output module for a programmable controller and explain why the current drain must exceed its holding current."
A: A triac output module operates as a solid state switch capable of conducting AC current. The current drain must exceed the holding current or the thyristers from which the triac is made from will not switch into conducting or on mode.
Good Afternoon, I am having issues with a triac output card and a solid state relay. The output is showing 120vac without a load, and when...
1,318
I just had a weird one last night and was wondering if anyone else has ever seen this. A SLC5/05, 7 slot rack. One thermocouple input, One 18...
2,114
Just looking to learn something today.... My understanding is that an output shorting on a SLC Triac card is a pretty standard card failure, with...
2,362
I'm replacing a 20 some year old PLC with 1A rated triac outputs driving 120v solenoid valves that are rated at .3A Holding Current (all i could...
1,269
Just wanted to know what are people's thought on a triac output versus relay output cards? I'm working with the Allen Bradley SLC line, 1747-OA16...
6,456
