Tricky application...suggestions welcome
russrmartin
Aug 2002
Eastman, Wisconsin
744
Hi guys. I would like to sense coated web running on a chained conveyor. The application looks something like this. Material fed through a coater which coats the web with one of several chemicals. As web exits the coater, it lies on a steel oven belt, which carries the web through the oven. I need to sense the the web coming out of the coater, as it sits on this steel belt. The belt has a fairly rought surface, and it tends to get dirty with whatever chemical they are coating with. Webs can get close to 1/4" thick. What I need is some kind of a sensor that will be able to ignore the rough surface of the oven belt, but still pickup the web riding on top of it. This sensor should be mounted outside the coater enclosure to keep it GP. If we try to mount inside the enclosure, we need to go explosion proof. This was suggested, but we cannot find an explosion proof laser sensor, and we are unsure of how a laser sensor mounted inside an EP box will react to looking though a glass window. Also, a see though style sensor is not an option as the reflector underneath the belt will buildup quickly with whatever it is at the time that they are coating with. Anyone have any ideas?
I would suggest a mechanical converter
You could let a steel harm hang down in such a way that it gets lifted by the web. Then let an ordinary prox sense the arm.
Make the arm height adjustable.
Try using a camera system and detect for color contrast. If it is too expensive, try wet coating reflective sensor, whose principle is based on absorbtion of light wave length. In our case the camera system worked well
Thanks guys.
I apologize for the vague visual. I can cut a hole in the top of the enclosure and look down at the belt carrying the web and keep this GP, but, this puts me about 4 feet from the belt.
The problem with a steel hanger, or dancer, or roller, is contamination from product to product. While possible, it would require cleaning.
I am not sure what a diffuse sensor is?
The vision system sounds like a possibility. Cost is always a problem, but we may be able to justify it in this case. Thanks for all the suggestions thus far. I will do some reasearch on the links posted.
The Lut3 is outstanding. I use two of them and never here a word about them. They just work.
How about a PEC with a short sensing distance which can be extended with steel wrapped fibre optic. The sensor is thenm external but the sensing head internal and close.
What material is the web, steel?
If you have an analog input you could use an ultra sonic sensor then in the program use a more than / less than logic to change a bit to give you a signal to stop the process or lamp or horn.
Just thinking,
Good Eve Gentlemen, We had this cold room which was converted to hot room before I joined this work. Everthing was fine until a month ago, they...
2,121
Hi Here's a question I'm about to ask Omron.. as soon as I can figure out who to ask.. It's complicated asking support.. their web email form...
3,117
I have a controller that gets turned on by the push of a momentary push button with one set of contacts, and remains on using a single SPDT non...
19
6,155
Hi all, I am just out of school and working in my first engineering position doing mostly PLC (SLC500) work at a small company. I have been...
3,582
We have faced a tricky problem . The panel view Plus 1000 is not going online..The network guy "Ping" from system and shows that the node is ok...
2,234
