Tristation 1131 software
cornbread
Feb 2007
madison, indiana
407
Earlier this week I upgraded my RSlogic 5000 to version 20.1 on my window XP machine. Today I tried to open my Triconex Tristation 1131 ver 4.1 software and got an UE0001 Unexpected application error. Anyone using Tristation 1131 ver 4.1 experience this problem?
On a side note.. I did call Triconex tech support and they wanted me to remove the AB software and reload 1131 software...will give that try on Monday.o_O
It was not the AB software causing the problem. The Tricon file I was trying to use was on my desktop and there was an issue with the DRA account certificate that expired and lock up my desktop. Had to download a fix from out IT folks.
This fixes access denied issue when saving files on encrypted folder (Desktop, My Documents, My Favorites...etc) due to DRA account certificates expiry on 24th June 2012.
HI any one famiilar with TRICON controllers, and Tristation 1131 developers workbench I would like to know if it is possible to program in both...
2,940
Gems and Gents, Does anyone know if it is possible to have Tristation 5.0 and Tristation 5.2 installed on the same machine? Whenever I install...
1,130
Hello, Does anyone have the Triconex Tristation serial cable pinout? The cable part number is 1600080-0xx.
1,157
Hi there, I'm trying to write values to Tristation Version 2.0 emulator (Version 3.0, Build 308), via Excel, using a VB command. The script seems...
1,303
I have an application running on a Triconex Tri-GP system and although I am able to read tags successfully via the DDE server, I am not able to...
5,395
