Triconex Tristation DDE Communications
Oct 2012
Mooresville
I have an application running on a Triconex Tri-GP system and although I am able to read tags successfully via the DDE server, I am not able to write to any tags.
The tags are memory based and I have assigned them a Read/Write alias
I have un-checked the “Disable remote changes to outputs” in the MP configuration.
When I try to poke a value to a tag, I get
“Write failed for NODE 1 tagname MyTag.DATA Reason : Unknown Reason 209”
Could anyone please suggest what I might be doing wrong?
Thanks for the reply. I saw something about the keyswitch in the docs but we have a Tri-GP which does not appear to have a run/program switch. Part of the problem is that the documentation refers to a number of models and its not easy to determine to which system it is referring to.
Can you think of anything else it may be? I do get a slightly different error message if I try to write to a read-only tag so I guess thats encouraging.
Try checking this docuemnt, found on the foxboro web site.
SYS_SET_REMOTE_WRT_ENBL A Tri-GP function block that programmatically allows or restricts write access to output or memory read/write aliased points when used in an application.
To allow write access, the Disable Remote Changes to Outputs
property cannot be checked.
Communication Guide for Tri-GP v2 SystemsCommunication Guide for Tri-GP v2 Systems06-Apr-20112,173 kb
I've been struggling with this for 9+ hours now. Trying to write from a DCS master to a Tri-GP slave emulator for testing.
This solved my issue as well, many thanks!
Hello, Does anyone have the Triconex Tristation serial cable pinout? The cable part number is 1600080-0xx.
1,149
Good Morning Folks, I'm having an issue with a triconex tri-gp. After 24-48 hours of runtime, I lose my SCADA connection to it, which I correct...
1,526
I often make modifications on tristation, automatically it will generate new versions sequence of events SOE format and I have to copy and paste...
3,548
Hi All, I am working on a Triconex project (Trident controller) which has a project specific function blocks library. I need to make some changes...
1,946
Hi Friends Please I needs help with Triconex work station -Tristation 1131 , I read manual thy didn't mention for uploading project from Triconex...
2,705
