Trouble with Siemens Analogue Input Cards
magdy580
Oct 2007
Cairo
I have a Siemens analogue input card 6ES7 331-7KF02-0AB0
The problem is that milli-amps is reaching to the channels of the card, but the input value is always 32768 and does not change with change of milli-amps.
The card is healthy in the hardware configuration and no faults are reported.
The input -of course- is not overwritten in any part of the program.
I replaced the card but the same problem occured.
I moved the inputs to a different card, it worked.
I am using a safety PLC 315F-2 DP
Does anybody know what can that be ?
Group, I had failure on a back plane of a ET200s Remote rack. The SF light was solid, and the BF light flashed as soon as you turned on power...
1,463
So long story short I'm frustrated at work because I can't get my timer to actually time in the FB's. I have been using the SB4 blocks in my FB...
3,134
I am completely unfamiliar with Siemens programming but I have been asked to become familiar with it. I have a new copy of TIA Portal V11 SP2...
12,383
I am not very familiar with S7 so maybe someone can help me out. We had a problem last night with an OB85 I/O failure fault that seemed to...
10,115
Dear All, I am having a 110kW vector drive SIMOVERT running at 50% at its full load capacity...The problem is I could not get current reading...
6,530
