Troubles with AOI PFlex 700
dingomex3
Mar 2012
mexico
33
Hello, I have troubles with AOI PowerFlex 700. When I want to use it into the logic it says the tags "Inp_PowerFlex_700" and "Out_PowerFlex_700" are boolean tags but in the inside logic these tags should be array tags. I attach pictures
I will appreciate your help with this issue...Thanks
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
143
  • Locked
  • Sticky
Hi folks, If you're having any login issues kindly send an email to [email protected] or use the 'contact us' link on the bottom of every page to get...
1,136
Hello all, I am currently addressing a failing screen on a PV550. The first thing I did was upload the program onto an Allen Bradley memory card...
29
7,348
Hey Folks. I'm having a little issue with a Kinetix350. Long story short. I have burned 2 2097-V34PR5-LM in the past few months on the same...
2,767
Hello! I'm a complete beginner to programming and i have a project i'm working on in TwinCAT 3 since i'm using a Beckhoff PLC. One of the...
2,354
