True Sine Wave Power a little OT
CroCop
Aug 2005
Utah
1,050
I'm looking at getting involved with a diamond press. The prospective lead engineer has quite a bit of experience with the mechanical end of things, and a little with controls. He suggests that to provide heat at the right moment, we need a true sine wave across the load, and the best way is an AC generator coupled with an AC motor driven by a frequency drive. Have any of y'all seen a canned outfit like this, preferabbly one I could send a 4-20mA signal to, and a 4-20mA signal back from for the power used?
Apparently, theres a bunch of those companies in your area.
I have seen a diamond press power setup that consisted of a motor operated variable transformer. The output of the var transformer then fed a stepdown transformer for heating the graphite. The transformer wiper was moved via servo-motor.
I did not notice who made it, so I cant be of much help, but it looked European (IEC) - not to mention it was several years ago.
Surely there is a better way to do this though. Why not use a SCR power controller and precision metering equipment?
I'm not an expert, but if you are creating heat through a (presumably) resistance heater the type of current - DC, pure sine wave, or poorly defined AC waveform - shouldn't make much difference. If you are using an inductive heater then the sine wave form may make a big difference. Have you contacted the source of your heaters for advice?
Software Ver. 22.00.00, After the 1st time of being true the EQL. instruction is still allowing the rung to be true even though the inputs are...
232
Have a noob question regarding OTL/OTU bits. Can someone look at the attached photo and tell me why both the OTL/OTU bits are true? Then they both...
1,966
Hello. I have struggled all my Saturday with this one issue, and it is clear that only someone far more knowledgeable than me on CoDeSys can...
2,604
Has anyone ever successfully used one of the fleaBay laptops with what would appear to be thousands of dollars of software e.g...
28
8,840
Hi all, I'm just starting out in the plc world. For school we had some introduction into codesys v3.5, basically we get given visualizations and...
2,433
