Trying to run RSlinx Service and Application
pilkingtonk
May 2014
niles
I just installed rslinx oem. I used to have lite. We got OEM so that we can send data to an OPC. I want to run linx as a service but I cant unless I go to the linx control panel and say always run as service, but if I do that, the application won't open. This problem did not exist before, so I was curious if any one had an idea?
If you check the always run as service box, the RSLinx application always starts automatically as a service, Windows 7 won't display the icon in the task bar.
I use the 'Always Run As Service' option, and then if I need to make changes to configurations, I un-check the box and use the RSLinx Launch Control Panel to start it. Once set up, I can go back go back to run as a service, and still use 'Who Active' through the RSLogix programs.
Hi I have a problem described below: I have a panelview application which is actually running on a 2711R-T4T panelview 800 which I call the "old"...
3,547
Anyone have any luck with running Studio on a MacBook, running Windows 10? I have it installed, but it won't see my activations on the Dongle. The...
1,676
Hey everyone. Basically i want to run a DVT camera on a conveyor belt, the purpose of that is for the camera to identify objects going past on...
2,846
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
141
