tsx 17
Try:
7 -> Data +(B)
14 -> Data -(A)
5 -> gnd
you may need to place a 150 ohm resistor (for terminating/biasing) across terminals 7 and 14.
can you make a picture for connection automate ----pc IN AND OUT
excuse my english( I AM A FRENCH)
You can not connect a standard computer RS232 serial port directly to a TSX17 PLC. The PLC programming port is 2-wire RS485.
You will need to get an RS232 to RS485 convertor. Each convertor manufacturer has their own configuration, so I can not provide a wiring diagram (picture).
Robust Data Com is one convertor manufacter. They have some good application notes in their support area.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
60
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
150
Hello Dear Experts I have to read 2 words (%MW300 / %MW301) in a M221 plc (TM221ME16R/G) which have a embedded ethernet port. the reader plc...
742
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
372
Hi All Desperatly trying to get hold of the software too upload a program from a TSX Nano. i thinkg the software is PL707. i have from PL7Pro...
424
