TSX37 serial communication
antoine
Sep 2002
62
Hello,
I am setting up a serial link between a TELEMECANIQUE (SCHNEIDER) TSX 37-22 and a PC.
I have a hard time with the PRINT_CHAR function and the help doesn't help (!). Does anyone of you have experience with this function ?
Any comment about the character mode communication on these machines are welcome.
Have a nice day...
Antoine.
What type of communication are you trying to create?
The Print_Char command would typically only be used to output an ASCII character string to a "dumb terminal", printer, or some other type of non-intelligent device.
Usually it is easier to write code (i.e. Visual basic) or to use a packaged HMI application in the computer.
Hi Jim,
Thanks for replying. Here is a bit more about what I am aiming to do:
The idea is to create a cheap and easy data logger for use on standalone PLC (without SCADA or HMI).
The PLC would be connecter to a PC using a standard terminal (Hilgraeve Hyperterminal) ans collect ASCII character strings. Integers are transmitted with a 5 digits format, bool one digit, plus a separator (#). So everything can easyly be opened by Excel for curves drawing.
This is mostly for home applications and using customer's computer without needing additionnal software or licenses.
I am using an RS485-RS232 converter, the hardware seems to be OK.
However I am a bit surprized by the trafic on the AUX port of the PLC, I suspect it is on the same network than the console port.
This may require some software filtering, no problem with that.
So, back to that PRINT_CHAR function, I am using adress "0.0.1.SYS" to daress the AUX port of my TSX37-22; my data are in a table ; the control words are %MW120 to %MW123. I tryed several combinations without succes. If you already used this function, how did you configure it?
I hope this helps focusing down the question.
Antoine.
Just in case anybody is interested in the solution:
Pins 5 and 7 of the connector have to be connected together to switch to character mode communication....
Stupid myself !
hello,please can you explain me how to install TSX37 operating system version 6.5 in pl7 pro
1,559
Hi, I want to connect a TSX micro PLC (modicon) to a OP277 Siemens Panel. I've done the research, it is written in de manuals that this is...
2,045
Hi all, i have to make a few minor changes to a Telemechanique TSX31-21 plc next week. I have never used the software before and know nothing...
2,090
I need to modify a Unitel-way communications driver to talk to Schneider-Telemecanique TSX 57's. Looking for the Unitel-way command frames that...
1,786
I'm looking for a way (gate, card, ....) to connect a TSX37 from SCHNEIDER to a profibus network (ET200S from SIEMENS). Who can help me.
2,292
