Tsxp572823 modicon premium plc cant connect
eababio
Jan 2011
Gaborone
52
I have a modicon plc amd trying to connect to it directly using plc7 pro and the tsxcusb485 . I entered SYS as plc address and configured al the other settings accoding to manual but still cnt connect to plc.has anyone encountered this issue before?
Do you have the driver installed? Is the driver pointing to the correct com port in the drivers manager?
Have you tried a reset of the driver?
What software are you using? (As i cant remember if this cpu is unity or pl7 pro)
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
269
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
219
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
135
